filter alarm table
Hello
I should only select alarms from the previous month and then export them to a csv file and send the whole thing via email.
But I thought about the query, I'm using the following code.
123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354555657585960616263646566676869707172737475767778798081828384858687888990919293949596979899100101102103104105106107108109110111112113114115116117118
--My (smtps) username !IMPORTANT! user = 'report@test.com' --My (smtps) password !IMPORTANT! password = 'xxxxxx' --Sender for e-mail from = '<' .. user .. '>' alias_from = 'Do not Reply ' --Recipient for e-mail to = '<xxxx@xxxx.com>' alias_to = to --Subject for e-mail subjectpart1 = 'Lista Allarmi Mese' subjectpart2 = 'E-Mail inviata in automatico dal WebServer' --Message on bottom of email (will only be showed when client don't understand attachment) epilogue = 'End of message' -- vedere come filtrare mese se 1 prendere 12 e anno -1 ---------------------------------------------------------------- if (os.date('%m')==1) then     mp=12     yr=os.date('%Y')-1 else      mp=os.date('%m')-1     yr=os.date('%Y') end ------------------------------------------------------------------ --log('MESE ' ..mp .. ' ANNO ' ..yr) -- Get all alerts from DB alerts_table = db:getall('SELECT * FROM alerts where alerttime like %'..mp..'.'..yr..'% ORDER BY id DESC') -- csv buffer buffer = {} -- format csv row csv = string.format('%q,%q,%q', "ID", "Messaggio", "Data e Ora") -- add to buffer table.insert(buffer, csv) -- add empty line to buffer table.insert(buffer, "") -- Loop through alerts_table for _, alerts in ipairs(alerts_table) do   -- format csv row   csv = string.format('%q,%q,%q', alerts.id, alerts.alert, os.date("%x %X", alerts.alerttime))   -- add to buffer   table.insert(buffer, csv) end      --Create table to include mail settings     local settings = {         from = from,         rcpt = to,         user = user,         password = password,         server = 'smtps.aruba.it',         port = 465,         secure = 'sslv23',     }     --Create attachment inside FTP server     src = os.date('%Y-%m') .. '.csv'     dst = '/home/ftp/' .. src     io.writefile(dst, buffer)     --Create subject     subject = subjectpart1 .. ": " .. src .. " " .. subjectpart2     --Load required modules to send email with attachment     local smtp = require("socket.smtp")     local mime = require("mime")     local ltn12 = require("ltn12")     --Create e-mail header     settings.source = smtp.message{     headers = {               from = '' .. alias_from .. ' ' .. from .. '',               to = '' .. alias_to .. ' ' .. to .. '',               subject = subject     },     --Load attachment inside body          body = {     preamble = "",      [1] = {              headers = {                ["content-type"] = 'text/plain',                ["content-disposition"] = 'attachment; filename="'..src..'"',                ["content-description"] = '.. src ..',                ["content-transfer-encoding"] = "BASE64",             },             body = ltn12.source.chain(               ltn12.source.file(io.open(dst, "rb")),               ltn12.filter.chain(               mime.encode("base64"),               mime.wrap()             )           )         },           epilogue = epilogue       }     }     --Send the email     r, e = smtp.send(settings)     --Create alert when sending gives an error with error message     if (e) then       log (e)       log (r)       alert("Could not send email: ", e, "\n")     end   --Delete created file from ftp folder inside HL   os.remove(dst)
taking into account that if month = 1 I have to take the data of month 12 and previous year
my problem is the select query I don't know how to filter the column data whose name I don't know (alarm date)
grazie
Date/time is stored as UNIX timestamp. Check for month number wrap is not needed, it is handled by the os.time() automatically.
date = os.date('*t') date.day, date.hour, date.min, date.sec = 1, 0, 0, 0 ts_end = os.time(date) date.month = date.month - 1 ts_start = os.time(date) alerts_table = db:getall('SELECT * FROM alerts where alerttime BETWEEN ? AND ? ORDER BY id DESC', ts_start, ts_end)
Keep in mind that alerts are deleted automatically, make sure that you've set the limit correctly in Utilities > General configuration.
(12.02.2021, 12:14)admin Wrote: Date/time is stored as UNIX timestamp. Check for month number wrap is not needed, it is handled by the os.time() automatically.
i'm trying the code but surely i'm wrong something, the code gives me the following values for the range
From 01/01/21 to - 02/01/21
I think there is a problem with the date format , swap day and month , i have a alarm inside but return nothing to export in csv
Thank's
Replace os.date("%x %X" with os.date("%F %X"
(12.02.2021, 13:04)admin Wrote: Replace os.date("%x %X" with os.date("%F %X"
I not have this entry in code
not work
Is possible to log  the return valu eof query fir control , or count number of row return ?
Post you full script listing otherwise it's impossible to find what's wrong with it. You can use log(any_variable_name) to log variable contents into Logs tab.
(12.02.2021, 13:45)admin Wrote: Post you full script listing otherwise it's impossible to find what's wrong with it. You can use log(any_variable_name) to log variable contents into Logs tab.
This is my complete script
--My (smtps) username !IMPORTANT! user = 'xxxx@xxx.com' --My (smtps) password !IMPORTANT! password = 'xxxx.' --Sender for e-mail from = '<' .. user .. '>' alias_from = 'Do not Reply ' --Recipient for e-mail to = '<xxx@xxx.com>' alias_to = to --Subject for e-mail subjectpart1 = 'Lista Allarmi Mese' subjectpart2 = 'E-Mail inviata in automatico dal WebServer' --Message on bottom of email (will only be showed when client don't understand attachment) epilogue = 'End of message' date = os.date('*t') date.day, date.hour, date.min, date.sec = 1, 0, 0, 0 ts_end = os.time(date) date.month = date.month-1 ts_start = os.time(date) alerts_table = db:getall('SELECT * FROM alerts where alerttime BETWEEN ? AND ? ORDER BY id DESC', ts_start, ts_end) --------------------------------------------------------------------------------- log('Dal - ' .. os.date("%x",ts_start) .. ' Al - ' .. os.date("%x",ts_end)) --------------------------------------------------------------------------------- -- csv buffer buffer = {} -- format csv row csv = string.format('%q,%q,%q', "ID", "Messaggio", "Data e Ora") -- add to buffer table.insert(buffer, csv) -- add empty line to buffer table.insert(buffer, "") i=0 -- Loop through alerts_table for _, alerts in ipairs(alerts_table) do   -- format csv row   log(tostring(i+1))   csv = string.format('%q,%q,%q', alerts.id, alerts.alert, os.date("%F %X", alerts.alerttime))   -- add to buffer   table.insert(buffer, csv) end    --Create table to include mail settings   local settings = {       from = from,       rcpt = to,       user = user,       password = password,       server = 'smtps.aruba.it',       port = 465,       secure = 'sslv23',   }   --Create attachment inside FTP server   src = os.date('%Y-%m') .. '.csv'   dst = '/home/ftp/' .. src   io.writefile(dst, buffer)   --Create subject   subject = subjectpart1 .. ": " .. src .. " " .. subjectpart2   --Load required modules to send email with attachment   local smtp = require("socket.smtp")   local mime = require("mime")   local ltn12 = require("ltn12")   --Create e-mail header   settings.source = smtp.message{   headers = {             from = '' .. alias_from .. ' ' .. from .. '',             to = '' .. alias_to .. ' ' .. to .. '',             subject = subject   },   --Load attachment inside body        body = {   preamble = "",    [1] = {            headers = {              ["content-type"] = 'text/plain',              ["content-disposition"] = 'attachment; filename="'..src..'"',              ["content-description"] = '.. src ..',              ["content-transfer-encoding"] = "BASE64",           },           body = ltn12.source.chain(             ltn12.source.file(io.open(dst, "rb")),             ltn12.filter.chain(             mime.encode("base64"),             mime.wrap()           )         )       },         epilogue = epilogue     }   }   --Send the email   r, e = smtp.send(settings)   --Create alert when sending gives an error with error message   if (e) then     log (e)     log (r)     alert("Could not send email: ", e, "\n")   end --Delete created file from ftp folder inside HL os.remove(dst)
The script looks correct. What do you get in logs? Do you actually have alerts for the previous month in Alerts tab?
You can try getting alerts for the current month by adding date.month = date.month + 1 after date = os.date('*t') (line 21)
Also don't use %x date format because it is MONTH/DAY/YEAR, use %F which is YEAR-MONTH-DAY.
(12.02.2021, 14:00)admin Wrote: The script looks correct. What do you get in logs? Do you actually have alerts for the previous month in Alerts tab?
tried as recommended changed to% F, the result does not change, could it be an international setting problem?
If I look at the alerts they are merited in the format 12.02.2021 hh:mmConfuseds
If you want this exact data time format then use os.date('%d.%m.%Y %X', alerts.alerttime)
(12.02.2021, 14:18)admin Wrote: If you want this exact data time format then use os.date('%d.%m.%Y %X', alerts.alerttime)
in the query sintax ?
Part of line 45. Don't change the query, it's already correct.
(12.02.2021, 14:25)admin Wrote: Part of line 45. Don't change the query, it's already correct.
done but nothing to do I always get back files with no line just headers.
The problem that with the query does not return anything, if instead I do a select * it returns the alarm, I'm afraid that the problem is the stored date format, how can I see the logicmachine db if possible?
in the previous post it was the format I see on the logicmachine
Thank you
There's no date format in the database, UNIX timestamp (integer) is used to store date/time. Either the query is incorrect or you don't have alerts matching the requested time-frame.
Run this script once and post what got get in Logs tab:
data = db:getall('SELECT COUNT(1) total, MIN(alerttime) tmin, MAX(alerttime) tmax FROM alerts') log(data)
(12.02.2021, 14:40)admin Wrote: There's no date format in the database, UNIX timestamp (integer) is used to store date/time. Either the query is incorrect or you don't have alerts matching the requested time-frame.
this is log
You only have 3 alerts in the database and the oldest one is from today. This is why you get an empty CSV when exporting previous month data.
(12.02.2021, 15:14)admin Wrote: You only have 3 alerts in the database and the oldest one is from today. This is why you get an empty CSV when exporting previous month data.
also use month+1 export nothing
Run this script to log alerts for the current month and post the result:
date = os.date('*t') date.month = date.month + 1 date.day, date.hour, date.min, date.sec = 1, 0, 0, 0 ts_end = os.time(date) date.month = date.month - 1 ts_start = os.time(date) alerts_table = db:getall('SELECT * FROM alerts where alerttime BETWEEN ? AND ? ORDER BY id DESC', ts_start, ts_end) -- csv buffer buffer = {} -- format csv row csv = string.format('%q,%q,%q', "ID", "Messaggio", "Data e Ora") -- add to buffer table.insert(buffer, csv) -- add empty line to buffer table.insert(buffer, "") -- Loop through alerts_table for _, alerts in ipairs(alerts_table) do   -- format csv row   csv = string.format('%q,%q,%q', alerts.id, alerts.alert, os.date("%d.%m.%Y %X", alerts.alerttime))   -- add to buffer   table.insert(buffer, csv) end res = table.concat(buffer, '\n') log(res)
