filter alarm table
#21
(12.02.2021, 15:27)admin Wrote: Run this script to log alerts for the current month and post the result:
date = os.date('*t') date.month = date.month + 1 date.day, date.hour, date.min, date.sec = 1, 0, 0, 0 ts_end = os.time(date) date.month = date.month - 1 ts_start = os.time(date) alerts_table = db:getall('SELECT * FROM alerts where alerttime BETWEEN ? AND ? ORDER BY id DESC', ts_start, ts_end) -- csv buffer buffer = {} -- format csv row csv = string.format('%q,%q,%q', "ID", "Messaggio", "Data e Ora") -- add to buffer table.insert(buffer, csv) -- add empty line to buffer table.insert(buffer, "") -- Loop through alerts_table for _, alerts in ipairs(alerts_table) do   -- format csv row   csv = string.format('%q,%q,%q', alerts.id, alerts.alert, os.date("%d.%m.%Y %X", alerts.alerttime))   -- add to buffer   table.insert(buffer, csv) end res = table.concat(buffer, '\n') log(res)
this is the result
This means that the export from DB to CSV part is working correctly. There must be something else wrong with your script if data is not populated.
(12.02.2021, 15:41)admin Wrote: This means that the export from DB to CSV part is working correctly. There must be something else wrong with your script if data is not populated.
But if I use
alerts_table = db:getall('SELECT * FROM alerts ORDER BY id DESC')
the script working fine.
filtering is probably the problem
Post the latest version of your script that should export current month data instead of previous
(12.02.2021, 16:59)admin Wrote: Post the latest version of your script that should export current month data instead of previous
This i scomplete scritp for currento mounth
--My (smtps) username !IMPORTANT! user = '...' --My (smtps) password !IMPORTANT! password = '...' --Sender for e-mail from = '<' .. user .. '>' alias_from = 'Do not Reply ' --Recipient for e-mail to = '<claudio@ciemme.com>' alias_to = to --Subject for e-mail subjectpart1 = 'Lista Allarmi Mese' subjectpart2 = 'E-Mail inviata in automatico dal WebServer' --Message on bottom of email (will only be showed when client don't understand attachment) epilogue = 'End of message' date = os.date('*t') -- recupera data e ora dalla tabella del db date.day, date.hour, date.min, date.sec = 1, 0, 0, 0 ts_end = os.time(date) date.month = date.month + 1 ts_start = os.time(date) alerts_table = db:getall('SELECT * FROM alerts where alerttime BETWEEN ? AND ? ORDER BY id DESC', ts_start, ts_end) --alerts_table = db:getall('SELECT * FROM alerts ORDER BY id DESC') --------------------------------------------------------------------------------- log('Dal - ' .. os.date("%F",ts_start) .. ' Al - ' .. os.date("%F",ts_end)) --------------------------------------------------------------------------------- -- csv buffer buffer = {} -- format csv row csv = string.format('%q,%q,%q', "ID", "Messaggio", "Data e Ora") -- add to buffer table.insert(buffer, csv) -- add empty line to buffer table.insert(buffer, "") -- Loop through alerts_table for _, alerts in ipairs(alerts_table) do   -- format csv row   csv = string.format('%q,%q,%q', alerts.id, alerts.alert, os.date("%d.%m.%Y %X", alerts.alerttime))   -- add to buffer   table.insert(buffer, csv) end    --Create table to include mail settings   local settings = {       from = from,       rcpt = to,       user = user,       password = password,       server = 'smtps.aruba.it',       port = 465,       secure = 'sslv23',   }   --Create attachment inside FTP server   src = os.date('%Y-%m') .. '.csv'   dst = '/home/ftp/' .. src   io.writefile(dst, buffer)   --Create subject   subject = subjectpart1 .. ": " .. src .. " " .. subjectpart2   --Load required modules to send email with attachment   local smtp = require("socket.smtp")   local mime = require("mime")   local ltn12 = require("ltn12")   --Create e-mail header   settings.source = smtp.message{   headers = {             from = '' .. alias_from .. ' ' .. from .. '',             to = '' .. alias_to .. ' ' .. to .. '',             subject = subject   },   --Load attachment inside body        body = {   preamble = "",    [1] = {            headers = {              ["content-type"] = 'text/plain',              ["content-disposition"] = 'attachment; filename="'..src..'"',              ["content-description"] = '.. src ..',              ["content-transfer-encoding"] = "BASE64",           },           body = ltn12.source.chain(             ltn12.source.file(io.open(dst, "rb")),             ltn12.filter.chain(             mime.encode("base64"),             mime.wrap()           )         )       },         epilogue = epilogue     }   }   --Send the email   r, e = smtp.send(settings)   --Create alert when sending gives an error with error message   if (e) then     log (e)     log (r)     alert("Could not send email: ", e, "\n")   end --Delete created file from ftp folder inside HL os.remove(dst)
You've made the change incorrectly, now filter starting date is after the ending date. This should produce correct filter period:
--My (smtps) username !IMPORTANT! user = '...' --My (smtps) password !IMPORTANT! password = '...' --Sender for e-mail from = '<' .. user .. '>' alias_from = 'Do not Reply ' --Recipient for e-mail to = '<claudio@ciemme.com>' alias_to = to --Subject for e-mail subjectpart1 = 'Lista Allarmi Mese' subjectpart2 = 'E-Mail inviata in automatico dal WebServer' --Message on bottom of email (will only be showed when client don't understand attachment) epilogue = 'End of message' date = os.date('*t') -- recupera data e ora dalla tabella del db date.day, date.hour, date.min, date.sec = 1, 0, 0, 0 ts_start = os.time(date) date.month = date.month + 1 ts_end = os.time(date) alerts_table = db:getall('SELECT * FROM alerts where alerttime BETWEEN ? AND ? ORDER BY id DESC', ts_start, ts_end) --alerts_table = db:getall('SELECT * FROM alerts ORDER BY id DESC') --------------------------------------------------------------------------------- log('Dal - ' .. os.date("%F",ts_start) .. ' Al - ' .. os.date("%F",ts_end)) --------------------------------------------------------------------------------- -- csv buffer buffer = {} -- format csv row csv = string.format('%q,%q,%q', "ID", "Messaggio", "Data e Ora") -- add to buffer table.insert(buffer, csv) -- add empty line to buffer table.insert(buffer, "") -- Loop through alerts_table for _, alerts in ipairs(alerts_table) do   -- format csv row   csv = string.format('%q,%q,%q', alerts.id, alerts.alert, os.date("%d.%m.%Y %X", alerts.alerttime))   -- add to buffer   table.insert(buffer, csv) end    --Create table to include mail settings   local settings = {       from = from,       rcpt = to,       user = user,       password = password,       server = 'smtps.aruba.it',       port = 465,       secure = 'sslv23',   }   --Create attachment inside FTP server   src = os.date('%Y-%m') .. '.csv'   dst = '/home/ftp/' .. src   io.writefile(dst, buffer)   --Create subject   subject = subjectpart1 .. ": " .. src .. " " .. subjectpart2   --Load required modules to send email with attachment   local smtp = require("socket.smtp")   local mime = require("mime")   local ltn12 = require("ltn12")   --Create e-mail header   settings.source = smtp.message{   headers = {             from = '' .. alias_from .. ' ' .. from .. '',             to = '' .. alias_to .. ' ' .. to .. '',             subject = subject   },   --Load attachment inside body       body = {   preamble = "",    [1] = {             headers = {              ["content-type"] = 'text/plain',              ["content-disposition"] = 'attachment; filename="'..src..'"',              ["content-description"] = '.. src ..',              ["content-transfer-encoding"] = "BASE64",           },           body = ltn12.source.chain(             ltn12.source.file(io.open(dst, "rb")),             ltn12.filter.chain(             mime.encode("base64"),             mime.wrap()           )         )       },         epilogue = epilogue     }   }   --Send the email   r, e = smtp.send(settings)   --Create alert when sending gives an error with error message   if (e) then     log (e)     log (r)     alert("Could not send email: ", e, "\n")   end --Delete created file from ftp folder inside HL os.remove(dst)
(15.02.2021, 07:49)admin Wrote: You've made the change incorrectly, now filter starting date is after the ending date. This should produce correct filter period:
perfect thank you very much
