luadmx library
Where can I find details or documentation about luadmx library please? Only thing I found are scripts which uses DMX.set() function. I would like to do script for dimming (different from that one and only available on internet).
Thank you
luadmx functions:
12345678910111213
dmx = require('luadmx').open(port) -- open port and create DMX instance dmx:send() -- send current channel values to DMX dmx:setchannel(channel, value) -- set channel (1..512) to the given value (0..255) value = dmx:getchannel(channel) -- get channel (1..512) value dmx:setcount(count) -- set number of channels to send (1..512) count = dmx:getcount() -- get number of channels to send dmx:setall(value) -- set all channels to the given value (0..255)
(15.02.2021, 08:25)admin Wrote: luadmx functions:
12345678910111213
Hi! does this mean I can change my old "DMX" user library for this internal?
There's no point unless you have some custom DMX control you want to use which cannot be created with the DMX library. The library uses luadmx internally anyway.
