16.02.2021, 06:34
is it possible to set up the built-in Mosquitoo broker to use the websocket protocol?
Using built-in MQTT broker over WebSocket
16.02.2021, 06:34
16.02.2021, 08:01
Websocket support is not enabled. Can you explain your use case for this?
I'm developing a web based smart home dashboard using the Paho JavaScript Client
16.02.2021, 10:12
LM has a websocket interface for objects, do you really need MQTT in your case? See this thread for an example: https://forum.logicmachine.net/showthrea...13#pid2913
16.02.2021, 10:21
(16.02.2021, 10:12)admin Wrote: LM has a websocket interface for objects, do you really need MQTT in your case? See this thread for an example: https://forum.logicmachine.net/showthrea...13#pid2913 I would prefer to use MQTT over websocket as a common protocol since I also will interact with other interfaces. Is there any problems/drawbacks to enable websocket support for the built-in broker. Regards Johan
16.02.2021, 10:24
The broker does not have the websocket protocol support compiled in.
16.02.2021, 10:32
Will websocket support be compiled into the broker in a near future, if not is it possible to install a custom package with websocket support enabled?
16.02.2021, 11:54
Maybe later but I can't promise anything at the moment.
04.02.2023, 08:08
any plans on implementing websocket support for MQTT in the future? Regards Johan
07.02.2023, 09:05
07.02.2023, 09:05
There's no custom package with websocket support.
