Reduce 0-100% to 10-100%
Hi!
What is the easiest way in the LM to reduce a 1 byte in percent from 0-100 to 10-100? I got a group address I want to send throug a "filter" and the result have to be from 10 to 100%.
Any ideas?  Smile
So minimum neds to be 10? Scaled so that 0=10 or that 10=10 but the output does not go lower?
Sent fra min SM-G980F via Tapatalk
(10.03.2021, 19:43)tomnord Wrote: So minimum neds to be 10? Scaled so that 0=10 or that 10=10 but the output does not go lower?
Yes, minimum 10%. 0 - 10 is equal 10, 11 = 11 %.
Event based script:
value = event.getvalue()
if value < 10 then
output = 10
output = value
grp.write('1/1/1', output)
Event based script with the 0-100 value GA as trigger.
At output you can use "grp.update('1/1/1', output) also...
