Modbus TCP
I am trying to figure how to get data from my heat pump via modbus tcp.
I have connection with my device:
But is there some kind of tutorial how to read/write data from my device in LM?
I got a parameter list from Nibe, with all the objects.
See this thread: https://forum.logicmachine.net/showthread.php?tid=903
(25.03.2021, 15:57)admin Wrote: See this thread: https://forum.logicmachine.net/showthread.php?tid=903
I have seen this, but is it different between MODBUS TCP and RTU?
If registry are the same then you can use same profile. Delete this part "bus_address": "4/1/0",
(25.03.2021, 16:11)Daniel. Wrote: If registry are the same then you can use same profile. Delete this part "bus_address": "4/1/0",
Can you show me an script example how to read this value in LM?
Try this and please link the whole documentation next time. I've set the address to 0 as it looks like you need to subtract 1 from the documented address. Try setting it back to 1 if reading does not work. You will have to delete the device and create it again after uploading updated profile.
{   "manufacturer": "NIBE Heat Pump",   "description": "VVM S320 / S325",   "mapping": [     {       "name": "Outdoor temperature (BT1)",       "bus_datatype": "float16",       "datatype": "int16",       "type": "inputregister",       "address": 0,       "value_multiplier": 0.1     }   ] }
