Json data to table problem
I have a problem with json data from the MQTT broker.
I receive this string from the MQTT : {"Redox": "954","Ph": "6.67","Temperatuur": "10.5","Error message": ""}
When I check it (https://jsonformatter.curiousconcept.com/#) is valid JSON data.
When i decode this with
payload = "{"Redox": "954","Ph": "6.67","Temperatuur": "10.5","Error message": ""}"
msg =  json.pdecode(payload)
The result is still a string instead of a table.
I guess i'm missing something obvious.
Can anyone help me?
Are you sure you are logging the correct variable - msg instead of payload? If pdecode fails then the msg variable will be nil, not a string.
Yes I’m sure
This is the code
mclient.ON_MESSAGE = function(mid, topic, payload)
local msg = json.pdecode(payload)
log ("Payload", type(payload)
log(type(msg),msg)
log(json.decode(msg).variable)
if type(msg) == 'table' then
Redox = msg.Redox
log("redox",Redox)
It's possible that the payload is encoded twice so you get a string after first decode. Try decoding the msg again and post what you get.
(28.03.2021, 12:23)admin Wrote: It's possible that the payload is encoded twice so you get a string after first decode. Try decoding the msg again and post what you get.
Indeed it was encoded twice.
Double decode solved it.
local msg = json.pdecode(json.pdecode(payload))
Thank you.
