Reset Router when Internet lost
I have my LogicMachine remotely behind a router. Sometimes the router looses the Internet for a minute and for unknown reasons the build in VPN does not restart. I have hooked up one KNX actor to the power of the router. Once a day I do I scripted on/off. That has solved the problem temporarily.
Question: how would I go about creating a script that checks if the Internet is available from the LM and if not sends an "off" and after a minute an "on" to the knx actor?
cheers!!!
Not sure if this is correct approach but you could try ping google.com. Use this script, you will get 0 on success.
ip = 'google.com' res = os.execute('ping -c 2 -W 1 ' .. ip) log(res)
(31.03.2021, 08:19)Daniel. Wrote: Not sure if this is correct approach but you could try ping google.com. Use this script, you will get 0 on success.
Thanks! So I did this:
ip = '192.168.0.1' res = os.execute('ping -c 2 -W 1 ' .. ip) if (res == 1) then   log("Reboot due to VPN down")   grp.write('4/1/2', false)   os.sleep(1.5)   grp.write('4/1/2', true) end
