07.04.2021, 08:53
		I want to add simple Textbox (inputbox) Like as Html Textbox component..
Is it posible do it with visulation or should i use Scripting ?
					Add simple Textbox for send value.
		07.04.2021, 08:53
		I want to add simple Textbox (inputbox) Like as Html Textbox component.. Is it posible do it with visulation or should i use Scripting ?
		07.04.2021, 13:45
	 (07.04.2021, 11:23)Daniel. Wrote: Why don't you just use Text Label? i want use text box like this for sent to a value maybe integer for dim value or Send a start time like as "08:50" or send Some Text .. and i need textbox style like this Why Not use text Label Because There isnt main object for write KNX address in Text Label properties
		07.04.2021, 13:56
		Well if you want to display text from an object then just use Display mode: value.
------------------------------ Ctrl+F5 |
