Deconz REST API
Hi.
I have successfully managed to controll Ikea blinds with REST API sent to Deconz.
I have tested this in the "Postman REST client" i google Chrome, and i sent the following:
192.168.1.80:40850/api/8EBFA5778F/lights/2/state/
PUT
{ "lift": 50 }
When "putting" these lines the blinds roll down to 50%
How do i implement these 3 lines in a script in LM?
Kai-Roger
Try this:
123456789101112131415
http = require('socket.http') ltn12 = require('ltn12') body = '{"lift":50}' res, code = http.request({   url = '192.168.1.80:40850/api/8EBFA5778F/lights/2/state/',   method = 'PUT',   headers = {     ['Content-Length'] = #body,   },   source = ltn12.source.string(body) }) log(res, code)
(19.04.2021, 06:31)admin Wrote: Try this:
Excellent Smile Thanks. I had to put in http:// in front of the url, but else it worked perfectly.
Kai-Roger
Hi again.
I tried to use a variable (Percent) inside the Json expression in the "body". This does not work. Any tips on how to do this?
12345678910111213141516171819
Percent    = event.getvalue    () http = require('socket.http') ltn12 = require('ltn12') --body = '{"lift":100}' body = '{"lift":Percent}' res, code = http.request({   url = 'http://192.168.1.80:40850/api/8EBFA5778F/lights/2/state/',   method = 'PUT',   headers = {     ['Content-Length'] = #body,   },   source = ltn12.source.string(body) }) log(res, code)
Kai-Roger
Use this:
body = require('json').encode({   lift = event.getvalue() })
(20.04.2021, 06:24)admin Wrote: Use this:
Excellent Smile
Kai-Roger
