14.04.2020, 20:23
Under Utilities -> Vis Config -> uncheck Show alerts in visualization:
Alert Manager
14.04.2020, 20:23
Under Utilities -> Vis Config -> uncheck Show alerts in visualization: BR, Erwin
24.06.2020, 11:09
Hello
Erwin, first of all thank you and congratulations for the app is very useful. Just one question, I have already seen that you cannot change the aspect as you commented previously, but is a Spanish translation possible? A fastener, adding a help, including the information of the frame, would not be bad. a greeting
24.06.2020, 13:52
Currently only EN en NL are supported BR, Erwin
27.06.2020, 15:23
thanks for the reply.
I hope you appreciate the proposal to include a help tab. a greeting
27.06.2020, 19:58
At this moment i have no time for adding any enhancements, when a project need might rise i will re-evaluate it.. BR, Erwin
23.09.2020, 13:15
I am using Alert Manager to view the alerts, but I have some setting problems, I am monitoring alarms based on event script but if septum event script does not work, also the automatic page change does not work, what am I wrong? BR
23.09.2020, 21:30
For page jump you need to enable the persistant checkbox on the iframe.
Can you eleborate on the second question? I have no idea what you mean..
12.01.2021, 09:31
Hello, can you help me install Alert manager? I don't have internet in a facility ... thanks
12.01.2021, 11:30
12.01.2021, 11:31
Go to app store even offline and in menu there is option install from file.
12.01.2021, 11:35
14.01.2021, 15:42
is it possible to hide this icon in visu?
14.01.2021, 15:50
I think you can only protect it by password in user settings
18.01.2021, 09:09
Hello
Is it possible to ensure that in the alert manager the tactic is password protected, not just the cancellation? thank you so much
Hello
With the update of wiser for KNX from version 2.5 to 2.6, I have noticed that the Alert manager application no longer appears in the store. I have installed it using the file from post 69. Why is it no longer available in the store? All the best
20.04.2021, 09:13
This is question to SE, from 2.6.0 wiser is using SE store and we are not managing it anymore. Up to now they were using our store.
20.04.2021, 10:50
This is in progress, i delivered the open source to our development team and they are preparing it for our own app store, should be there in the near future..
OK understood.
I've already asked SE. Thanks for her reply. a greeting (20.04.2021, 10:50)Erwin van der Zwart Wrote: Esto está en progreso, entregué el código abierto a nuestro equipo de desarrollo y lo están preparando para nuestra propia tienda de aplicaciones, debería estar allí en un futuro cercano. Thanks for your answer. All the best
02.06.2024, 16:41
Hi there, can i acknowledge an alarm in a script? I am writing a script that uses grp.readvalue response timeout. It would be nice if i could achnowledge the alam in the script so the customer sees that a device was offline but since the alarm is acknowledged i he knows that the device is back online. or is there a better way to do so?
The script still has an issue so i don't want to post it right now... Thanks for your help |
