Run an Event Script with Page Name
I have an event scripts like :
Event Script for Floor 1
Event Script for Floor 2
and also i have pages like :
Floor 1
Floor 2
I need that if user open Floor 1 in visualation, event script "Event Script for Floor 1" will run once.
How can i do that ?
Regards,
If you are referring to Mosaic then this is not possible because it does not have Custom JavaScript support. In standard visualization there's a showplan event that is triggered when a new plan is opened. See this: https://forum.logicmachine.net/showthrea...6#pid20146
(23.04.2021, 12:19)admin Wrote: If you are referring to Mosaic then this is not possible because it does not have Custom JavaScript support. In standard visualization there's a showplan event that is triggered when a new plan is opened. See this: https://forum.logicmachine.net/showthrea...6#pid20146
In that example, if a new plan is opened, script orients to otherplan. I dont want to orient the page to other plan. I need to run an event script instead of orienting to other plan. Can you help for this specific need please ?
Change plan IDs, group addresses and values as needed.
$(function(){   if (typeof grp == 'undefined') {     return;   }      $('body').on('showplan', function(event, id) {     if (id == 2) {       grp.write('0/0/1', 50);     }     else if (id == 3) {       grp.write('0/0/1', 90);     }   }).trigger('showplan', [ currentPlanId ]); });
