Problems with javascript write to bus
I am trying again. Hope somebody can help me Smile
<!DOCTYPE html> <html> <head>   <meta charset="UTF-8">   <script src="http://192.168.10.111/apps/js/jquery.js.gz"></script>   <script src="http://192.168.10.111/apps/js/localbus.js.gz"></script>   <script src="http://192.168.10.111/scada/vis/busdecode.js.gz"></script> </head> <body> <script> $(function() {   // listen to all groupwrite telegrams   localbus.listen('groupwrite', function(event) {     console.log(event);   });   localbus.init('http://192.168.10.111, admin:admin');   }); </script> </body> </html>
I found this code from another post her in the forum, but I need some help to get it right.
I am trying to write a value from my browser to LM, I have tried different codes but I think there is no connection between the javascript and LM.
And when I check the console in my browser no errors are there, but no log info from the bus either.
What am I missing? I have read this posts about Websockets but I am a beginner at this scripting thing so I don't understand it all.
I have also added websocket.lua (a file from another post) in my user library in LM.
Line 19 is wrong, replace it with this:
localbus.init('http://192.168.10.111', 'admin:admin');
(03.05.2021, 10:09)admin Wrote: Line 19 is wrong, replace it with this:
Hi, that worked like a charm.
Thank you very much Smile
Hi again,
Where in the code above should I put my write function? Can you give me an example?
Example:
<!DOCTYPE html> <html> <head>   <meta charset="UTF-8">   <script src="http://192.168.10.111/apps/js/jquery.js.gz"></script>   <script src="http://192.168.10.111/apps/js/localbus.js.gz"></script>   <script src="http://192.168.10.111/scada/vis/busdecode.js.gz"></script> </head> <body> <button id="example">Click to write</button> <script> $(function() {   // listen to all groupwrite telegrams   localbus.listen('groupwrite', function(event) {     console.log(event);   });   localbus.init('http://192.168.10.111', 'admin:admin');   $('#example').click(function() {     localbus.write('0/0/10', true);   }); }); </script> </body> </html>
(04.05.2021, 06:22)admin Wrote: Example:
Thank you, now I have something to work on Smile
