Tulikivi sauna heater relay board
Hello
Could somebody help me with Tulikivi relay board for the sauna heater, trying to read sauna temperature with CMD 11, but the result always 0. When I connecting my touch panel, then pannel starts asking for data from the relay board and a log is showing some values. So the connection is established, but the request is wrong.
12345678910111213141516171819
require('serial') port, err = serial.open('/dev/RS485', {   baudrate = 9600,   databits = 8,   stopbits = 1,   parity = 'none',   duplex = 'half' }) port:flush() port:write(0xB) data = port:read(2,3) byte = string.byte(data) log(string.format("%o, %x, %d", byte,byte,byte)) port:close()
protocol attached
Thank you
.pdf   softa mat.pdf (Size: 91.39 KB / Downloads: 12)
Try this:
1234567891011121314151617181920212223242526272829303132333435363738394041424344454647
require('serial') port, err = serial.open('/dev/RS485', {   baudrate = 9600,   databits = 8,   stopbits = 1,   parity = 'none',   duplex = 'half' }) function send(cmd, data)   local msg, res, err, b1, b2   data = data or 0   msg = string.char(     bit.band(cmd, 0xFF),     bit.band(bit.rshift(data, 8), 0xFF),     bit.band(data, 0xFF)   )   port:flush()   port:write(msg)   res, err = port:read(2, 3)   if type(res) == 'string' then     if #res == 2 then       b1, b2 = res:byte(1, 2)       return bit.bor(bit.lshift(b1, 8), b2)     else       return nil, 'invalid reply'     end   else     return nil, err   end end -- turn on res, err = send(1, 1) log(res, err) -- turn off res, err = send(1, 0) log(res, err) -- read current temperature res, err = send(15) log(res, err)
