Script change in database activation
when i am changing a script in the database, how can i activate this change?
Today the change is only affecting after a restart of the lm
thanks
What exactly are you changing and what is the type of the script?
I am changing the script itself.
I want to upload a script with ftp and the lm have to import it. I have 52 SL to update the script automatic everytime i update my masterscript.
It works but only with restart. I think there must be a better option.
The script to edit is a resident
My Import script is actual:
file = '/home/ftp/importscripts/script.lua' if io.exists(file) then log('start scriptimport') data = io.readfile(file) db:query('UPDATE scripting SET script=? WHERE name=?', data, 'imported_from_ftp') os.remove (file) os.execute("reboot") end
What type of script is this? Event, resident, scheduled?
Both scripts are resident.
Use this:
123456789101112131415161718
data = [[alert('testing')]] name = 'imported_from_ftp' item = script.get(name) if item then   item.script = data   -- update script code in the database   db:update('scripting', { script = data }, { id = item.id })   -- update script code in the filesystem   script.save(item, true)   -- restart script   script.disable(name)   script.enable(name) end
Thanks, works without problems
