ZeroTier Service via LUA
hi,
I used to interact with openVPN Client by disabling by default the connection at server startup
require('uci')
uci.set('openvpn-lm', 'openvpn', 'enabled', 0)
uci.commit('openvpn-lm')
os.execute('/etc/init.d/openvpn-lm restart)
is there a way to di the save for zerotier client?
I've tried to replace zerotier-one to openvpn but it was an unsuccesful tentative Sad
thanks
enabled = event.getvalue()
require('uci')
uci.set('zerotier', 'default', 'enabled', enabled and 1 or 0)
uci.commit('zerotier')
os.execute('/etc/init.d/zerotier restart')
Thanks you so Mich
Is there a Place to understand the UCI module and its options and funcs?
Each service has different config options. This is not documented because it's an internal function.
require('uci')
Hi Daniel,
Can you help me with a script for Enable and Disable the Zerotier from a GA?
Im running a Iot Edge and want to restrict the data usage, and want to remotly enable / disable Zerotier from Mosaic.
Best Regard
Even Sundgot.
Just create event script on boolean object. Add it to mosaic and done.
Is there anyway to get the Zerotier's IP via script?
You can get the IP like this:
info = io.readproc('zerotier-cli -D/var/lib/zerotier-one_default/ -j listnetworks')
info = require('json').pdecode(info)
if type(info) == 'table' then
  net = info[1]
  if type(net) == 'table' and type(net.assignedAddresses) == 'table' then
    ip = net.assignedAddresses[1]:gsub('/%d+', '') --remove subnet part
log(ip)
Thanks!
