Opening Links inside a Frame
Hi Guys,
Hope everything´s OK in these difficult days...
I'm making a Visu, and trying to make a left scroll menu, using a Frame with overflow in CSS
I'd like to know if exist a way to Opening the links from inside the frame in the full page instead of the frame, looking for a full view and not this result
Thank you guys in advance
B.R.
I suggest using the standard menu in docked mode (you can set this in Vis. configuration) and adjust it via CSS as needed.
