os.date with timezone offset
Is there a smart way to get the local time using os.date(), including the DST (Daylight Saving Time)? I would not like to add a hard-coded integer to the timestamp, but instead use something that calculates it for me, based on the timezone and taking account the DST.
Actually, is there a way to set the timezone in LogicMachine, so the local time of os.date() is correct?
You can set the timezone in Utilities > Date and time.
(24.04.2021, 18:53)mishoboss Wrote: Is there a smart way to get the local time using os.date(), including the DST (Daylight Saving Time)? I would not like to add a hard-coded integer to the timestamp, but instead use something that calculates it for me, based on the timezone and taking account the DST.
Only os.date() reports the right time back for timezone. None of the %r or %X or %z or %Z works as they should according to strftime - no matter what is set in timezone in Utilities > Date and time.
You can get the right time for timezone by extracting the time from os.date()
ef:
TimeOfDayStr = string.match(os.date(), "%d%d:%d%d:%d%d")
os.date('%z') correctly reports the timezone offset accounting the DST.
