Zero tier
Is there an package for the imx28cpu to use zero tier like this
https://openrb.com/zerotier-remote-maintenance-of-lm5/
(08.03.2021, 07:50)benanderson_475 Wrote: Is there an package for the imx28cpu to use zero tier like this
1457 views and nobody knows?
i also tried https://openrb.com/zerotier-remote-maintenance-of-lm5/
on lm5 with imx6 cpu, i have installed the packages in step 6 but cannot find the Zero tier config option after installing the packages and rebooting, i confirm packages are installed, but step 9 as per above link,  under services i cant find ZeroTier to enable it.
9. Go to System Configuration -> Services -> ZeroTier
Must be something simple i am missing
Which LM do you have? You need new firmware.
(10.03.2021, 09:23)Daniel. Wrote: Which LM do you have? You need new firmware.
Lm5p2-DR
Use this, https://dl.openrb.com/lm-20-imx6/lm5m3ex-20201111.img
You will have to install the packages again.
Is Zero Tier also with lm2i possible ?
We didn't compile this for old cpu, for now not.
(10.03.2021, 09:59)Daniel. Wrote: Use this, https://dl.openrb.com/lm-20-imx6/lm5m3ex-20201111.img
Thanks Daniel,
i updated firmware as per link above and installed pkg again, i still not find the zero tier config tab after reboot
Clear browser cache
(11.03.2021, 08:30)Daniel. Wrote: Clear browser cache
Many thanks, i have it working now!!
Is this firmware also suitable for LM5p2-KC?
Yes it is
Hi , i cannot find zerotier packages for new and old cpu ?
Can you share links please ?
Just install RC1, old hw will not get zerotier.
I have new hw lm5 lite. I updated Firmware. I will install the packages but i cannot find the packages. Can somebody share please ?
If you installed RC1 then it is already there, no need to install packages anymore.
Oh ok. It's because browser cache. Thank you.
Is Zero Tier already available for the old cpu?
It's only available for the new CPU.
