Find an Object in Visualization
Hello
Is it possible to find objects in the visu also in the script?
I have a customer who claimed that an AC unit runs by itself at random times, I added that value to the log to check source address in future events.
but for now, I want to check that I didn't use this object by mistake in another place in the visu or in the script.
regards,
Best Regards,
In Scripts-Tools you can print scripts. Use search in there to check if you used this object.
(26.07.2021, 07:41)Daniel. Wrote: In Scripts-Tools you can print scripts. Use search in there to check if you used this object.
Thanks, Daniel I forgot this option regarding Script.
But is there something to find/search in visu?
Best Regards,
Use this script to log all plan names where a certain object is used:
id = buslib.encodega('1/1/1') plans = db:getlist([[   SELECT vf.name FROM visfloors vf   JOIN visobjects vo ON vf.id=vo.floor   WHERE vo.object=? ]], id) log(plans)
(26.07.2021, 10:14)admin Wrote: Use this script to log all plan names where a certain object is used:
thank you, admin
this is very helpful
Best Regards,
