Got a LM5 i.MX6 with most recent fw (20210510) and I?m experiencing a wired issue
IP configuration is correct.. I can ping 8.8.8.8 and traceroute www.google.com correctly, but.. all lua script that uses socket.http library goes in timeout error.
luasocket library is version 2.0.2-20210217
This of course will prevent any script to run as they are intended.
Is is an issue someone else has faced and fixed?
thanks
Regards
P.S.
this is the script:
variable "code" result timeut
...it is not a timeout parameter issue
this is an example.. I do have the telegram notification script that doesn't work either
thanks
Regards
P.S.
this is the script:
require('json')
local http = require('socket.http')
http.TIMEOUT = 30
local OWMLINK = 'https://api.openweathermap.org/data/2.5/onecall?'
local OWMAPIKEY = ''
local OWMUNIT = 'metric'
local OWMLAT =
local OWMLON =
local OWMLANG = 'it'
local OWMEXCLUDE = 'minutely,hourly'
OWMLINK = OWMLINK..'lat='..OWMLAT..'&lon='..OWMLON..'&appid='..OWMAPIKEY..'&units='..OWMUNIT..'&exclude='..OWMEXCLUDE
log(OWMLINK)
local OWMResponse, code, headers, status= http.request(OWMLINK)
log(code, status, headers)
if not OWMResponse then
alert('Previsioni OpenWeather: Impossibile recuperare dati')
return
local data = json.pdecode(OWMResponse)
if not data then
alert('Previsioni OpenWeather: Impossibile convertire dati')
return
