Scrit HTTP request timeout
Got a LM5 i.MX6 with most recent fw (20210510) and I?m experiencing a wired issue
IP configuration is correct.. I can ping 8.8.8.8 and traceroute www.google.com correctly, but.. all lua script that uses socket.http library goes in timeout error.
luasocket library is version 2.0.2-20210217
This of course will prevent any script to run as they are intended.
Is is an issue someone else has faced and fixed?
thanks
Regards
P.S.
this is the script:
require('json')
local http = require('socket.http')
http.TIMEOUT = 30
local OWMLINK    = 'https://api.openweathermap.org/data/2.5/onecall?'
local OWMAPIKEY  = ''
local OWMUNIT    = 'metric'
local OWMLAT     =
local OWMLON     =
local OWMLANG    = 'it'
local OWMEXCLUDE = 'minutely,hourly'
OWMLINK = OWMLINK..'lat='..OWMLAT..'&lon='..OWMLON..'&appid='..OWMAPIKEY..'&units='..OWMUNIT..'&exclude='..OWMEXCLUDE
log(OWMLINK)
local OWMResponse, code, headers, status= http.request(OWMLINK)
log(code, status, headers)
if not OWMResponse then
  alert('Previsioni OpenWeather: Impossibile recuperare dati')
  return
local data = json.pdecode(OWMResponse)
if not data then
  alert('Previsioni OpenWeather: Impossibile convertire dati')
  return
variable "code" result timeut
...it is not a timeout parameter issue Wink
this is an example.. I do have the telegram notification script that doesn't work either
Try Like this,
require('json')
local OWMLAT     = '41.8719'
local OWMLON     = '12.5674'
local OWMResponse, err= http.request( OWMLINK..'lat='..OWMLAT..'&lon='..OWMLON..'&lang='..OWMLANG..'&exclude='..OWMEXCLUDE..'&appid='..OWMAPIKEY..'&units='..OWMUNIT)
log(OWMResponse, err)
if OWMResponse then
   log(data)
  else if err then
  log('ERROR :' .. err)
thnaks...
I found the issue.... I made a BAD mistake on the NAT setup on my router....
it is now working good
thanks
ciao
M
