Wiser: modbus rtu write to knx tp
Hello there,
Is there anyway to send to knx bus tp all the values of modbus rtu? Not only when value changes
Thank you!
If you don't touch the delta then all will be sent. You can easily flood the bus this way with many registers.
(16.09.2021, 09:29)Daniel Wrote: If you don't touch the delta then all will be sent. You can easily flood the bus this way with many registers.
I really need that certain registers always be sent to the bus, regardless of the delta.
