28.09.2021, 05:37
	 Hello
 HelloDid anyone make a flashing alert by Scrip?
Someone can help or send a scrap, of course in no-alert mode, the flicker stops. Regards
					flashing alert
		28.09.2021, 05:37
	  Hello Did anyone make a flashing alert by Scrip? Someone can help or send a scrap, of course in no-alert mode, the flicker stops. Regards
		28.09.2021, 05:45
		Do you want to do this in standard visualization or Mosaic? What kind of alert do you want - an icon or text label? What type is the alert object - 1 bit or something else?
		28.09.2021, 15:55
	 (28.09.2021, 05:45)admin Wrote: Do you want to do this in standard visualization or Mosaic? What kind of alert do you want - an icon or text label? What type is the alert object - 1 bit or something else? Greetings   Thanks for the reply I want an alert in the icon, in 1 bit, I did not understand what is visualization or Mosaic. I work in a visualization screen. Thanks
		You can do it with a transparent picture if there is no problem and a animated gif with to pictures in it, 1 transparent and one with symbol of problem you want. something like this ![[Image: Alert.gif]](https://upload.wikimedia.org/wikipedia/commons/e/e7/Alert.gif) sourch: https://commons.wikimedia.org/wiki/File:Alert.gif
		29.09.2021, 06:12
		Animated GIF is an easy solution. This can also be achieved with Custom JavaScript. This example will show/hide all elements with additional class set to alert every second when 0/1/24 value is set to true. You can also change $('.alert').removeClass('hide'); to $('.alert').addClass('hide'); to hide the element when the object value is false. Code: $(function(){
		29.09.2021, 07:34
	 (29.09.2021, 06:12)admin Wrote: Animated GIF is an easy solution. great and easy, alternative to creating GIF. But how to make it depend on the element value (Binary) instead of a specific object?
Best Regards,
		29.09.2021, 08:16
		You can find the mapped group address like this: https://forum.logicmachine.net/showthrea...5#pid20275
	 (29.09.2021, 08:16)admin Wrote: You can find the mapped group address like this: https://forum.logicmachine.net/showthrea...5#pid20275 Thank you admin for advising me to do it by myself. This is what I did is there any advice? Code: // Flashing Alert
Best Regards,
		29.09.2021, 10:33
	 (29.09.2021, 10:22)khalil Wrote:(29.09.2021, 08:16)admin Wrote: You can find the mapped group address like this: https://forum.logicmachine.net/showthrea...5#pid20275 Thanks for the answers I will try thanks
		29.09.2021, 10:36
		If you reference $('.alert') further in the code this means that all elements with alert class will be flashed if at least one objects is set to true. So it won't work for multiple/different alert objects. Try this (not tested): Code: $(function() {
		29.09.2021, 11:11
	 (29.09.2021, 10:36)admin Wrote: If you reference $('.alert') further in the code this means that all elements with alert class will be flashed if at least one objects is set to true. So it won't work for multiple/different alert objects. Try this (not tested): That's right, I didn't notice that because I tested it on one object your script seems to work fine, I tested it for two objects and work fine
Best Regards,
		29.09.2021, 19:53
	 (29.09.2021, 06:12)admin Wrote: Animated GIF is an easy solution. Hello I entered the script but I have a lot of error messages you can check it again thanks ? p.s my object 1/7/20 thanks
		30.09.2021, 07:00
	 (29.09.2021, 19:53)Nir70 Wrote:(29.09.2021, 06:12)admin Wrote: I used the script and its works fine. do you insert the script in the custom JavaScript page: Scripting> Tools> Edit custom JavaScript
Best Regards,
		30.09.2021, 08:52
	 (30.09.2021, 07:00)khalil Wrote:Thanks, I inserted the scrap as you just said. How now I enable it after inserting a JavaScript page: Scripting> Tools> Edit custom JavaScript?(29.09.2021, 19:53)Nir70 Wrote:(29.09.2021, 06:12)admin Wrote:
		[quote pid="23203" dateline="1632991948"] Thanks, I inserted the scrap as you just said. How now I enable it after inserting a JavaScript page: Scripting> Tools> Edit custom JavaScript? [/quote] Just save To see the effect you should open the PC/Tablet Page if you are using SL or W4KNX. you will not see the effect on the visualization editor page.
Best Regards,
		30.09.2021, 10:42
	 (30.09.2021, 09:00)khalil Wrote: [quote pid="23203" dateline="1632991948"] Just save To see the effect you should open the PC/Tablet Page if you are using SL or W4KNX. you will not see the effect on the visualization editor page. [/quote] Hi, I'm not a JAWA expert. Do I need to add value / object to what you sent? I tried through the screen non-flashing visual, I just need a sample object 1/7/10 (1 bit) in the sample problem so it flashes at about 0 it does not flash. Thanks
		30.09.2021, 10:55
		Use this code https://forum.logicmachine.net/showthrea...3#pid23183 and add additional calss 'alert' to your object in visu editor.
------------------------------ Ctrl+F5
		06.10.2021, 05:40
	 (28.09.2021, 17:13)Dré Wrote: You can do it with a transparent picture if there is no problem hello Thank you very much, is this an icon you created? Can I create or change captions myself? ERRO for example? Regards
		06.10.2021, 07:33
		Create two images and convert them to gif, there are loads of sw available for example this https://imgflip.com/gif-maker
		06.10.2021, 11:16
	 (28.09.2021, 17:13)Dré Wrote: You can do it with a transparent picture if there is no problem I tried thanks I took the same symbol (Alert) but the flicker disappeared |
