	Threads: 3
Is there any easy way to log all packets coming from source 15.15.* ? (without making a tag on all objects)
I have some units that use 15.15.* when they are starting up and after a while change the address to the right configured address. And I want to log if these units have any other strange behavior.
Regards
Klaus
	Threads: 161
		Hi Klaus,
you could use such script and customize handleLog function according to your needs.
if not client then
  require('genohm-scada.eibdgm')
  objects = grp.all()
  datatypes = {}
  for _, object in ipairs(objects) do
    datatypes[ object.id ] = object.datatype
  function handleLog(src, eventType, ga, value, rawEvent)
    local isLoggedAddress = src:find("15.15.%d+") ~= nil
    if isLoggedAddress then
      log(src, eventType, ga, value, os.time())
  function writehandler(event)
    local dpt, dst = datatypes[ event.dstraw ], event.dst
    local value = nil
    if dpt then
      value = knxdatatype.decode(event.datahex, dpt)
    handleLog(event.src, event.type, dst, value, event)
  client = eibdgm:new({ timeout = 0.5 })
  client:sethandler('groupwrite', writehandler)
-- handle knx
client:step()
You could look also into these posts:
https://forum.logicmachine.net/showthrea...ght=eibdgm
Done is better than perfect
	Threads: 161
		Awesome!
