change virtual onject value from script
Greetings
I should change some setpoints between summer and winter, the setpoints are stored in virtual objects, the scrip is run but the virtual objects are not updated.
-- COMMUTAZIONE INVERNO / ESTATE -- CONTROLLO TEMPERATURE ------------------------------------------------ STS = event.getvalue() --log(tostring(STS)) SPE = grp.getvalue('32/7/40') --log('SP ESTATE '.. tostring(SPE)) SPI = grp.getvalue('32/7/12') --log('SP INVERBNO '.. tostring(SPI)) if (STS==0) then -- INVERNO     grp.write('32/1/10', SPI)     grp.write('32/1/11', SPI)     grp.write('32/1/12', SPI) elseif (STS==1) then   grp.write('32/1/10', SPE)     grp.write('32/1/11', SPE)     grp.write('32/1/12', SPE) end ----------------------------------------------- thank's
I suppose STS value is boolean. You need to change STS==0 to STS==false and STS==1 to STS==true
thank's
