OVERLOAD TP
Greetings
I have a problem since yesterday without modifying anything, the LM goes into overload
thanks a lot
Greetings
thanks a lot
one of image is wrong
Seems you have high bus load. Try to debug why.
A lot of repeats. Looks like KNX loop.
(02.12.2021, 08:38)Daniel Wrote: A lot of repeats. Looks like KNX loop.
some idea to find why ?
I have change nothing in programm.
Connect using ETS and check which device is sending a lot of telegrams
Usually it happens when there is second IP router connected. I know nothing about your project so hard to say.
Change KNX multicast and see if ti helped
Actually IP shows 0 so this is probably a script loop or something on KNX side
