homelynk web: ERR_CONNECTION_REFUSED
Hello there
I got a problem. With out changing anything in my system for the past 6-8 months. (have not used the web interface for long). when I now on my internal IP network try to access my homelynk server I get this error message from browser (tried several different browsers and computers).
I have tried to power cycle the unit. The unit is HW version 1.xx. All functions om KNX scripting works fine (all the one I have programmed over time and use everyday, KNX functions, mail functions when snail mail receives in post box). I can also program KNX units using the homelynk as a bridge from LAN to KNX…
Open for ideas, what is wrong?
Tue
Did you try accessing it with direct URL.
http://IP/scada-main
(13.12.2021, 08:37)Daniel Wrote: Did you try accessing it with direct URL.
Hi there
Thx, but yes I did, same problem
Tue
It looks like some file system are corrupted. If you can't access web server then only thing is new card and complete re flash.
(13.12.2021, 14:48)Daniel Wrote: It looks like some file system are corrupted. If you can't access web server then only thing is new card and complete re flash.
OK, do you have a link or anything how to? I´m new in flash how to...
Tue
https://openrb.com/reflash-logicmachine3...-software/
Use this image for recovery http://dl.openrb.com/recovery.img.gz
SE has application note for this too.
