28.08.2015, 13:35
Hi to all.
I am looking for some help on how to create a library in order to call some functions provided by the Synology Surveillance Station API found here.
[url=http://global.download.synology.com/download/Document/DeveloperGuide/Surveillance_Station_Web_API_v2.0.pdf][/url]
The idea is to be able to turn on/off the notification setting of this recorder, so for example, if I arm my alarm system, the KNX bus knows, so through a relative LM script I can then enable the camera recorder to start sending me notification emails (i.e if movement detection), and if I disarm the alarm, the script will disable the notifications.
In the recorder API documentation I understand that it support control through JSON commands and more specifically, I need to modify each time the boolean parameter "mailEnable" of the "SetSetting" Method (page 243) like this:
GET /webapi/entry.cgi?
mailEnable=1 (or 0 accordingly)
Also as I understand from the NetATMO scripting presented at another thread, this must be similar with what I am looking for, but since I am a very new at programming (and LUA and LM in general) can somebody help me with some basic guidelines to start a little faster?
Thank you all in advance.
