HTML widget in mosaic
Is it possible integrate the status of a virtual object in the HTML widget in mosaic3?
For example, I created a text field, is it possible fill it with the value of a virtual object?
Best regards Cristian
Can you describe what are you trying to achieve? Is this not possible to do with a custom widget?
(14.01.2022, 12:00)admin Wrote: Can you describe what are you trying to achieve? Is this not possible to do with a custom widget?
Ok I think to understand what you want to do, widget creator -> image -> text field..... Ok I think it could be done.
Hi Admin,
I'm working on Widget creator and I think I can do what I want. But an information when I try to insert an image. How can I use an Image on LM folder?
I had tried with ../user/image.png but doesn't work.
Hi Admin,
I 've got......  I have found a answer in this post: https://forum.logicmachine.net/showthrea...+on+mosaic
best regards Cristian
