curl to lua
I am trying to convert a curl command to lua but cannot get it to work...
This is the curl command:
curl -X POST \ -H 'Content-Type: application/json' \ -d '{"jsonrpc":"2.0", "id":1", "method": "Input.Down"}' \ http://user:passwd@192.168.0.24:8080/jsonrpc
Result:
{"id":"1", "jsonrpc":"2.0", "result":"OK"}
This is the lua code:
socket = require('socket.http') socket.TIMEOUT = 5 url = 'http://user:passwd@192.168.0.24:8080/jsonrpc' body = '{"jsonrpc": "2.0", "id": 1, "method": "Input.Down"}' res, code = socket.request({     url = url,     method = 'POST',     body = body,     headers = {'Content-Type: application/json'         } })                        log(res) log(code)
This results in:
testing 22.01.2022 16:14:46 * number: 200 testing 22.01.2022 16:14:46 * number: 1
Any hints?
TIA.
Try this:
require('socket.http') require("ltn12") res = {} body = '{"jsonrpc":"2.0","id":1,"method":"Input.Down"}' socket.http.request({   url = "http://user:passwd@192.168.0.24:8080/jsonrpc",   method = 'POST',   sink = ltn12.sink.table(res),   headers = {     ['content-length'] = #body,     ['content-type'] = 'application/json',   },   source = ltn12.source.string(body), }) log(res)
(22.01.2022, 22:58)Erwin van der Zwart Wrote: Try this:
This works!
Bedankt Erwin!
Specifying sink is not needed in newer firmwares. The library will create a sink automatically and will return the request result as a string.
(24.01.2022, 07:08)admin Wrote: Specifying sink is not needed in newer firmwares. The library will create a sink automatically and will return the request result as a string.
I am on 20160714 firmware...
