Philips Hue Tunable white
How do I get it out that I can change the color temperature by a percentage value, either via the absolute color temperature 7,600 or via a 4-bit dimming step 3,007
with this script.
Can someone help me, I'm a complete novice  Huh
function setBrightnessCT(Light_num,brightness,ct)   if brightness == 0 then     body_msg = '{"on":false}'     response = sendToLight(lamp_id,body_msg)     return response   else     brightness = math.floor((brightness / 1) + 0.5)     brightness = math.floor((brightness * 2.54) + 0.5)       ct = math.floor(1000000 / ct)     ct = math.min(500, ct)     ct = math.max(154, ct)     --HTTP request send     body_msg = '{"on":true,"bri":'..brightness..',"ct":'..ct..'}'     return sendToLight(Light_num,body_msg)   end end
You need an event script mapped to the color temperature object. Then you can call this function like this, replace 123 with your light number and 1/1/1 with the brightness control object address:
light_num = 123 brightness = grp.getvalue('1/1/1') ct = event.getvalue() setBrightnessCT(light_num, brightness, ct)
I've now tested the whole thing.
but get the message.
User script:5: attempt to call global 'setBrightnessCT' (a nil value)
stack traceback:
User script:5: in main chunk
Make sure you have hue user library and add require('user.hue') to the beginning of your script.
Many Thanks
it works
Anyway to control from Mosaic 3.0 Hue RGBW-ledstripes with color temperature and RGBW?
