I have a project where Dali 2.0 motion detectors are installed (B.E.G PICO-BMS DALI-2), is there a possibility to receive the 24bit telegrams sent by the motion detectors with the LM ?
Regards
Thomas
LM can receive such telegrams but the parsing has to be done using scripts at the moment. We have plans to implement DALI 2.0 later.
You should also take into account that DALI bus is really slow and it can be easily overloaded if you attach many sensors to a single line.
the speed will not be the problem in my case we have few luminaire groups on the dalibus and only a few of these sensors, how can i listen to the bus ? i cannot find the appropriate command, https://openrb.com/docs/dali.htm
thank you
At this moment receiving telegrams is only supported via an external CANx-DALI interface. Internal DALI interface on Reactor devices and external RS-485 gateways do not support this.
