11.03.2022, 09:42
After updating my LM5 to lm5m3-20211215, I can't reach it on the network even I made a reset.
LM5
11.03.2022, 09:42
11.03.2022, 09:46
Were you able to perform HW factory reset and the LEDs reacted correctly?
In this case the safest option is to reflash the card https://openrb.com/reflash-logicmachine3...-software/
14.03.2022, 16:37
How should the LEDs react ?
14.03.2022, 19:08
When you hold reset button for first 10s led 2 will be red and it will flash red after 10s, release and press again. After 10sec will flash faster.
18.03.2022, 09:25
18.03.2022, 09:29
Does any LED comes on when you power it up?
18.03.2022, 09:30
Yes the first led, and it will turn on and off every 2,3s
18.03.2022, 09:34
It flashes red every two seconds with very low light
18.03.2022, 09:36
The same thing
18.03.2022, 09:37
Re flash the SD card, to be 100% sure you should use new card.
Ctrl+F5 |
