RSS Reader
I want to show on visualization some rss feed. Is there some example of this functionality? Or maybe some library which help to work with xml files?
You can use LuaSocket to fetch the RSS feed and the parse it using LuaExpat:
http://w3.impa.br/~diego/software/luasoc...ml#request
https://matthewwild.co.uk/projects/luaex...mples.html
Thanks, i didnt know which module, to handle with xml, you add.
Can you give me some working example of luaexpat? this, on the web you gave, is very strange and non documented, so understanding is very difficult.
Here's an example that will get text from <title> and <description> tags inside of each <item> tag and save them in a table.
12345678910111213141516171819202122232425262728293031323334353637383940414243444546474849505152535455565758596061626364656667686970717273747576777879
itemtag = false result = {} -- callback for tag start function starttag(parser, tag)  -- create new storage in result table for each <item> tag  if tag == 'item' then    itemtag = true    table.insert(result, {})  end  currtag = tag end -- callback for tag end function endtag(p, tag)  if tag == 'item' then    itemtag = false  end  currtag = nil end -- callback for character data function cdata(parser, text)  -- check if parser is inside of <item> and either in <title> or <description>  if itemtag and currtag then    if currtag == 'title' then      result[ #result ].title = text    elseif currtag == 'description' then      result[ #result ].description = text    end  end end -- create parser lxp = require('lxp') parser = lxp.new({  StartElement = starttag,  EndElement = endtag,  CharacterData = cdata, }) -- sample data data = [[ <?xml version="1.0" encoding="UTF-8" ?> <rss version="2.0"> <channel> <title>RSS Title</title> <description>This is an example of an RSS feed</description> <link>http://www.example.com/main.html</link> <lastBuildDate>Mon, 06 Sep 2010 00:01:00 +0000 </lastBuildDate> <pubDate>Sun, 06 Sep 2009 16:20:00 +0000</pubDate> <ttl>1800</ttl> <item>  <title>Example entry</title>  <description>Here is some text containing an interesting description.</description>  <link>http://www.example.com/blog/post/1</link>  <guid isPermaLink="true">7bd204c6-1655-4c27-aeee-53f933c5395f</guid>  <pubDate>Sun, 06 Sep 2009 16:20:00 +0000</pubDate> </item> <item>  <title>Another example entry</title>  <description>Here is some other text containing an interesting description.</description>  <link>http://www.example.com/blog/post/1</link>  <guid isPermaLink="true">7bd204c6-1655-4c27-aeee-53f933c5395f</guid>  <pubDate>Sun, 06 Sep 2009 16:20:00 +0000</pubDate> </item> </channel> </rss> ]] if parser:parse(data) then  log(result) else  log('parse failed') end
The best and the fastest support in KNX world Smile
