RSS Reader
I want to show on visualization some rss feed. Is there some example of this functionality? Or maybe some library which help to work with xml files?
You can use LuaSocket to fetch the RSS feed and the parse it using LuaExpat:
http://w3.impa.br/~diego/software/luasoc...ml#request
https://matthewwild.co.uk/projects/luaex...mples.html
Thanks, i didnt know which module, to handle with xml, you add.
Can you give me some working example of luaexpat? this, on the web you gave, is very strange and non documented, so understanding is very difficult.
Here's an example that will get text from <title> and <description> tags inside of each <item> tag and save them in a table.
itemtag = false
result = {}
-- callback for tag start
function starttag(parser, tag)
 -- create new storage in result table for each <item> tag
 if tag == 'item' then
   itemtag = true
   table.insert(result, {})
 currtag = tag
-- callback for tag end
function endtag(p, tag)
   itemtag = false
 currtag = nil
-- callback for character data
function cdata(parser, text)
 -- check if parser is inside of <item> and either in <title> or <description>
 if itemtag and currtag then
   if currtag == 'title' then
     result[ #result ].title = text
   elseif currtag == 'description' then
     result[ #result ].description = text
-- create parser
lxp = require('lxp')
parser = lxp.new({
 StartElement = starttag,
 EndElement = endtag,
 CharacterData = cdata,
-- sample data
data = [[
<?xml version="1.0" encoding="UTF-8" ?>
<rss version="2.0">
<channel>
<title>RSS Title</title>
<description>This is an example of an RSS feed</description>
<link>http://www.example.com/main.html</link>
<lastBuildDate>Mon, 06 Sep 2010 00:01:00 +0000 </lastBuildDate>
<pubDate>Sun, 06 Sep 2009 16:20:00 +0000</pubDate>
<ttl>1800</ttl>
<item>
 <title>Example entry</title>
 <description>Here is some text containing an interesting description.</description>
 <link>http://www.example.com/blog/post/1</link>
 <guid isPermaLink="true">7bd204c6-1655-4c27-aeee-53f933c5395f</guid>
</item>
<item>
 <title>Another example entry</title>
 <description>Here is some other text containing an interesting description.</description>
</item>
</channel>
</rss>
if parser:parse(data) then
 log(result)
 log('parse failed')
The best and the fastest support in KNX world Smile
