Curl to Lua -- govee led
Dear, as I am a novice in scripting. Anyone that can help me send a Put request for my govee led stip.
curl --location --request PUT 'https://developer-api.govee.com/v1/devices/control' --header 'Govee-API-Key: 0af6b18b-0303-4c87-b68a-xxxxxxxxx' --header 'Content-Type: application/json' --data-raw '{"device": "FF:AA:A4:C1:xx:xx:xx:xx","model": "H6199","cmd": {"name": "turn", "value": "off"}}'
Govee api reference sample request :
Request URL: https://developer-api.govee.com/v1/devices/control
Request Method: PUT
Request Header:
Content-Type : application/json
Govee-API-Key : 00000000-729c-4b82-b536-000000000
Request body
"device": "34:20:03:15:82:ae",
"model": "H6089",
"cmd": {
"name": "turn",
"value": "on"
12345678910111213141516171819202122232425262728293031
json = require('json') http = require('socket.http') ltn12 = require('ltn12') url = 'https://developer-api.govee.com/v1/devices/control' key = '00000000-729c-4b82-b536-000000000' body = json.encode({   device = '34:20:03:15:82:ae',   model = 'H6089',   cmd = {     name = 'turn',     value = 'on'   } }) resp = {} res, code = http.request({   url = url,   method = 'PUT',   headers = {     ['Content-Type']  = 'application/json',     ['Content-Length'] = #body,     ['Govee-API-Key'] = key,   },   source = ltn12.source.string(body),   sink = ltn12.sink.table(resp), }) log(res, code, resp)
bad request as answer:
* arg: 1
* number: 1
* arg: 2
* number: 400
* arg: 3
* table:
[1]
* string: <html>
<head><title>400 The plain HTTP request was sent to HTTPS port</title></head>
<body>
<center><h1>400 Bad Request</h1></center>
<center>The plain HTTP request was sent to HTTPS port</center>
</body>
</html>
Which firmware version do you have?
(22.04.2022, 14:37)admin Wrote: Which firmware version do you have?
I updated to latest version and then it works perfect. Thank you very much.
