22.04.2022, 11:37 (This post was last modified: 26.04.2022, 13:14 by Novodk.)
I can't create an account on the "Wiser for KNX" android app it says": Specified device has not been found on the network. You must be connected to the same network as the device for the registration. change Network and press ok, or cancel the registration." But if i click "Local Control (home network)" and type in the local IP address it works. I know about the 5 minuets after reboot, but that doesn't work either.
25.04.2022, 15:17 (This post was last modified: 25.04.2022, 15:28 by Novodk.)
(24.04.2022, 18:27)pioneersteffen Wrote: I had the same problem at the beginning. Have you installed and activated the „cloud connector“ app on the W4K?
26.04.2022, 13:17 (This post was last modified: 26.04.2022, 13:22 by pioneersteffen.)
How is the cloud symbol look like? Is it shown like attached?
If I remember correctly the SE support employee told me you need to wait approximately 100s after restart bevor you try to registrate the Wiser.
I'm new to the forum and also new to Wiser for Knx ,
Thanks admins for the approval,
I'm having the exactly same issue, and reading these posts, I though i write to SE directly, but had no reply,
Could you please share how did they or you managed to solve the "no device found on your network"
