knxproj file over 200kB can't convert to ESF
I try to use converter from knxproj file to ESF using utility:
http://openrb.com/convert/
but my .knxproj file is over 200KB Sad  What to do?? In ETS not so many groups, but file aprox. 925KB.
What do you recommend??
Alex
P.S. I checked other project's files - they are big enough - 13.5Mb...
ESF utility is for fixing ESF file locale. You need to use http://openrb.com/knxproj/ to convert knxproj to JSON which then can be imported to LM.
Oh, yes, just forgot.
Big Thanks!!! Smile
Hello, I try to use the link to convert the objects to Json but now I get this message and this tool does not work 'Please use built-in KNX project import in LM'
What for? In latest fw you can import whole knx.proj directly.
(27.05.2022, 10:28)Daniel Wrote: What for? In latest fw you can import whole knx.proj directly.
So no idea how to get it. The objects imported in LM are not copied to CAN and I have tried to load the project within the CAN app and it gives an error.
What are the steps?
There's a CANx app test version with KNX project import built-in:
https://dl.openrb.com/pkg/canx-20220420.ipk
https://dl.openrb.com/pkg/canxdali-20220420.ipk
(27.05.2022, 11:02)admin Wrote: There's a CANx app test version with KNX project import built-in:
Thanks Admin, I did not see the way to do it as Daniel indicated.
The regulation objects (4 bits) continue to cause problems and discard them as invalid.
