01.06.2022, 15:11
		Hi.
I have about 100 1-byte scaling values that I want to calculate maximum of by tagging them all with i.e "Max_value".
But if I for some reason there are object(s) that NOT should be included in the calculation temporarily, is it possible to toggle them off if I have digital value(s) for each in my visu?
Or is the only solution to go into scada-main and remove the tag for the desired value(s) ?
