Do you have KNX/IP filtering enabled? Maybe there are many message on the IP backbone? If messages are filtered they won't appear in the statistics but might cause high CPU load.
Disable KNX/IP features and check if the load is still high. Then you can switch from KNX/TP to IP mode temporarily to check if KNX/TP is at fault.
