Send data from LM over IP
I'm using the next script p1-smart-metering for reading out my smart meter over P1 port. This is working fine.
I also want use this data on another server and want sent it over IP.
part of the script to show what i mean. *rule 9 and 16
if data then   --log(data)     -- Totaal verbruik tarief 1: nacht- of weekendtarief uitlezen kWh   tarief_1 = data:match'1.8.1%((%d+.%d+)'   tarief_1 = tonumber(tarief_1) --log("Tarief 1 nacht- of weekendtarief: " .. tarief_1 .. " kWh")   grp.checkupdate('13/0/28', tarief_1) sent this data over IP on port 19928 (if the value chanced)           -- Totaal verbruik tarief 2: dagtarief uitlezen kWh   tarief_2 = data:match'1.8.2%((%d+.%d+)'   tarief_2 = tonumber(tarief_2)   --log("Tarief 2 dagtarief: " .. tarief_2 .. " kWh")   grp.checkupdate('13/0/29', tarief_2) sent this data over IP on port 19929 (if the value chanced)
This is the first time i use a IP command.
I hope someone can help me with how to do this.
Is it TCP or UDP? Is there some specific protocol or the value should be sent as a string without any conversion?
What i want is sent these data to another server with 'Domoticz' aka 'Home Assistent'.
and read this value with these servers.
there is no conversion needed.
UDP is enough
Use this:
data = tostring(tarief_1) sock = require('socket').udp() sock:sendto(data, '192.168.1.204', 19928) sock:close()
Yes thanks, it is working
