active State Icon
Hello
What Is the active state icon in the link and how to use it?
Best Regards,
From LM docs: Icon that is displayed when the link points to the current plan. Can be used in Layouts to create a plan menu.
(27.06.2022, 13:29)admin Wrote: From LM docs: Icon that is displayed when the link points to the current plan. Can be used in Layouts to create a plan menu.
Best Regards,
Hello:
I want to change the element "Link" textColor when tne "Display mode" is in Value mode, Is it posible?, Can I do it using javascript?
I know that element "Link" with "Display mode" as Icon, I can choose the Icon when the page is active, but in Value mode I can not choose any text style when the page is active.
Could you help me about it, I want to change not only the menú Icon I want to change too the text color when the page is active.
Thank you very much, best regards
Roger
As we have 3 Visualization tools, it would be good to say which one do you use?
(10.10.2025, 10:01)Daniel Wrote: As we have 3 Visualization tools, it would be good to say which one do you use?
I am talking about "scada-vis", visualization for PC/Tablet
thank you very much
Roger
For all relevant plan links set Additional classes to plan-link plan-link-123 where 123 is plan id to which the link refers.
Custom JS:
$(function() {   var prevId;   function onshowplan() {     if (prevId) {       $('.plan-link-' + prevId).removeClass('active');     }          if (currentPlanId) {       $('.plan-link-' + currentPlanId).addClass('active');         prevId = currentPlanId;     }   }      $('body').on('showplan', onshowplan);   onshowplan(); });
Custom CSS:
.plan-link.active {   color: red; }
(14.10.2025, 08:50)admin Wrote: For all relevant plan links set Additional classes to plan-link plan-link-123 where 123 is plan id to which the link refers.
Custom JS:
Custom CSS:
Thank you very much, it works very well, but I had to add in custom CSS the parameter !important
.plan-link.active {
  color: red !important;
Thank you so much, good work,
best regard, Roger
