01.07.2022, 12:05
With RS485 , Im trying to control a blind.
Controlling works fine but when the bilnd gives LM the status string, It seems to be returning the same stirng repeatedly.
In the log image that I attached, at 20:35:43 I get a string which tells me that bilnd is at 65% position
and when the bilnd reached at 90% position at 20:35:49, I get the same string again along with the string tells me that blind is at 90% position.
Is there any problem with my script or is it seems to be a specification of the blind itself?
if not port then
require('serial')
port = serial.open('/dev/RS485-1', {
baudrate = 9600,
databits = 8,
stopbits = 1,
parity = 'even',
duplex = 'half'
line = ''
function split(str, delim)
-- Eliminate bad cases...
if string.find(str, delim) == nil then
return { str }
local result = {}
local pat = "(.-)" .. delim .. "()"
local lastPos
for part, pos in string.gfind(str, pat) do
table.insert(result, part)
lastPos = pos
table.insert(result, string.sub(str, lastPos))
return result
function str2hex(str)
raw_len = string.len(str)
i = 1
while i <= raw_len do
current_hexvalue = '0x' .. string.format("%02x", string.byte(str, i))
if value then
value = value .. ', ' .. current_hexvalue
value = current_hexvalue
i = i + 1
return value
res, err = port:read(30, 6)
--port:flush()
if res then
decoded = str2hex(res)
-- log(decoded)
t = split(decoded, "0x10, 0x02")
--log(t)
for k,v in pairs(t) do
log(v .. 'STATUS RETURNED')
