Scripts for multiple group addresses?
I will be periodically writing values of various group addresses to an external MySQL database and will have a common function (writedb) for database connection and writing. I now will have to provide an event script for every group address, something like
writedb('1/1/10', event.getvalue())
Is there an easier way to this instead of having tons of event scripts (one per group address) with just this one liner, where I manually have to adjust the group address in each and every script?
Thanks & best regards,
Robin
You can map scripts to tags. Also, you are missing () for getvalue in your example. This example might help as well: http://forum.logicmachine.net/showthread...69#pid1269
Perfect, that is exactly what I need. Thanks!
Edit: fixed the missing ()
