GPS for LM-IoT-Edge
Hey,
I want to read the current GPS position from the GPS antenna that is attached to the controller.
How do i install the necessary gpsd package, it doesn't work with opkg.
The only solution at this moment is to read the data using Lua serial library and then parse it. This library can be used for parsing: https://github.com/1nv1/luaGPS
(04.08.2022, 06:53)admin Wrote: The only solution at this moment is to read the data using Lua serial library and then parse it. This library can be used for parsing: https://github.com/1nv1/luaGPS
And how do i read from the device? A quick test with:
require('serial')
port, err = serial.open('/dev/ttyUSB1')
log(port, err)
-- script will wait for 10 characters for 20 seconds
data, err = port:read(10, 20)
log(data, err)
Only gave me this output:
test 04.08.2022 16:41:51
* arg: 1
  * luaserial
* arg: 2
  * nil
test 04.08.2022 16:42:11
* arg: 1
  * nil
* arg: 2
  * string: timeout
You need to start GPS by sending AT+CGPS=1\r\n to /dev/ttyUSB2. This has to be done on every system boot. You can also try sending AT+CGPSAUTO=1\r\n to enable automatic GPS start.
