Simple Staircase Timer
Hi.
I need help with a simple staircase timer script. Staircase with after dimming with two step.
When the trigger gets true 1/1/1, Timer 1 and Timer 2 starts and Set Value High to 1/1/2 Output.
After ten minutes the Set Value Low is set to 1/1/2 Output. If the time runs out it should write Set Value Off.
But every time the trigger recive true the timer 1 and 2 is retrigged.
If timer 2 is active and the trigger recive true it should set 90%.
1/1/1 Trigger Staircase 1bit
1/1/2 Output 1byte
Set Value High 90%
Set Value Low 20%
Set Value Off 0%
Set Timer 1 = 10min
Set Timer 2 = 20min
Br
Resident script with 0 sleep time. Adjust timers table as needed. This script can handle multiple timers.
if not client then   timers = {     ['1/1/1'] = {       output = '1/1/2', -- dimmer control (0..100%)       onvaluehigh = 90, -- high output value in %       onvaluelow = 20, -- low output value in %       timeouthigh = 10 * 60, -- time to keep high value (in seconds)       timeoutlow = 10 * 60, -- time to keep low value (in seconds)     }   }   function timersetstate(timer, state)     grp.checkwrite(timer.output, timer['onvalue' .. state] or 0)     timer.state = state     timer.ticks = timer['timeout' .. state]   end   function timertimeout(timer)     local state = timer.state == 'high' and 'low' or 'off'     timersetstate(timer, state)   end   for _, timer in ipairs(timers) do     timer.state = 'off'   end   grp.sender = 'tm'   client = require('localbus').new(0.1)   client:sethandler('groupwrite', function(event)     local timer = timers[ event.dst ]     if timer and event.sender ~= grp.sender then       local value = tonumber(event.datahex, 16) or 0       if value == 1 then         timersetstate(timer, 'high')       end     end   end) end client:loop(1) for _, timer in pairs(timers) do   if timer.ticks then     timer.ticks = timer.ticks - 1     if timer.ticks == 0 then       timertimeout(timer)     end   end end
Thank you very much for the help.
Hi again.
Is it possible to have a slave input to retrigger the timer when it is active?
1/1/2 Output 1byte
1/1/3 Slave Input
Set Value High 90%
Set Value Low 20%
Set Value Off 0%
Set Timer 1 = 10min
Set Timer 2 = 20min
if i only want the staircase timer to send 90% when its trigged, and the time is out it send 10%
Remove timeoutlow and the timer won't go into off state.
timers = {   ['1/1/1'] = {     output = '1/1/2', -- dimmer control (0..100%)     onvaluehigh = 90, -- high output value in %     onvaluelow = 10, -- low output value in %     timeouthigh = 10 * 60, -- time to keep high value (in seconds)   } }
