11.09.2022, 06:32
I am having some frustrating issues in determining what is happening with regards to writes failing after a previous read has occurred when using Lua Modbus.
A Description of what is occuring.
Using Lua a connection is opened and maintained to the modbus tcp slave.
Values are first read from the device to determine its current state. All read results are working fine with correct values returned from the device.
Depending on values read a new value is written to the unit. and then the previous values are read again to verify the change has occurred.
When run in this format - after the write registers occurs, the logged result is
arg: 1
nil
arg: 2
string: Operation timed out
and then the following reads of values also return a Nil. where they previously returned a values prior to write.
The interesting result is if closing the connection and re-opening it, the value that was attempted to be written was successful. as reading again on a new connection works just fine.
note i have tried using delays (sleep(1)) as example between each item it has made no impact.
I have also Verified, that if the only action is to do a connection and write it works correctly.
returns
arg: 1
number: 1
arg: 2
nil
Can anyone provide some assistance as to why this issue is occurring after a write event only when inside a single connection.
I have thought that it might be just some form of time out, but currently i can not find any documentation on luamodbus to increase timeout for write and read
arg: 1
nil
arg: 2
require('luamodbus')
mb = luamodbus.tcp()
mb:open('192.168.1.175', 1501)
res, err = mb:connect()
if res then
log("connected!")
mb:setslave(1)
local r6 = mb:readregistervalue(0xE004, "uint16", "n")
log('Mode = '.. tostring(r6))
r6 = mb:readregistervalue(0xE008, "float32", "n")
log('Backup= '.. tostring(r6))
r6 = mb:readregistervalue(0xE00A, "uint16", "n")
log('Default = '.. tostring(r6))
if (r6 == 1) then
res,err = mb:writeregisters(0xE00A, 7)
log(res,err)
log('Backup = '.. tostring(r6))
log('connect failed', err)
mb:close()
if res then
log(res,err)
returns
arg: 1
number: 1
arg: 2
nil
