Running out of Group Addresses
I'm working with a Schneider Clipsal CBUS SHAC where the Group Address range 0/250/xxx is defined as the 'User Parameter application.
This range of group addresses can have objects with data types of String, Boolean, Integers, Dates, Strings etc.
And while I can create a second 'User Parameter 2' application at 0/48-127/0-254 for example, these custom application ranges only seem to support numeric values (0-254).
I assume this is particular to the Schneider Clipsal CBUS units.
Is there away of creating a second 'User Parameter 2' application at 0/48-127/0-254 which supports  String, Boolean, Integers, Dates, Strings etc (the same as the existing User Parameter group at 0/250/0-254)
Kind Regards
James
As far as I know user parameter range is up to 65535 not 255.
That's great news - I hadn't thought to try adding a new address beyond the usual 254, however I've just tested and it works.
Many thanks.
Kind Regards
James
