Speed to on/off
Hi, i nedd to change status on/off of knx adress if speed exceed 10%, can you help please?
This event script will send ON (true) to 1/1/1 when event value is larger than 10, otherwise it will send OFF (false) to 1/1/1.
value = event.getvalue() grp.checkwrite('1/1/1', value > 10)
(22.09.2022, 12:39)admin Wrote: This event script will send ON (true) to 1/1/1 when event value is larger than 10, otherwise it will send OFF (false) to 1/1/1.
what is wrong on my script below
if event.getvalue() > 10   then grp.write('2/3/5', true)   else grp.write('2/3/5', false)   end
Yours works fine. Thank you
Your script does the same thing as mine. Not sure why it didn't work for you. I've tested and it works for me.
